400 d head gasket
RLH
04-20-2008 17:59:57
Im helping a friend replace a head gasket on a 400 d it is a copper looking type of gasket. do I put any coating on it? the head was cracked any advice on what to look for. thanks for your help
INCase
04-21-2008 13:05:40
 Re: 400 d head gasket in reply to RLH, 04-20-2008 17:59:57
Victor does not suggest putting anything on their gaskets, however I didn"t get them to seal without. Hopefully your heads are good and flat. If your heads were cracked and you had any antifreeze in the oil,k take a look at the main and rod bearings as antifreeze in the oil will wreck the bearings pretty quickly. Good luck. Let us know what luck you have.
C. Amick
04-20-2008 19:29:24
I always spray my head gaskets with copper spray gasket coating to improve chances of it sealing.
Jim McVay
04-21-2008 16:19:11
 Re: 400 d head gasket in reply to C. Amick, 04-20-2008 19:29:24
I 2nd the use of cooper coat spray gasket sealer
