430 Case
Durkee
04-19-2008 16:28:58
I bought a 430 Case dsl. Someone told me that it has the same engine 188CI as in the 630 and you could turn up the pump to make it around 50HP. Is that true? And how hard is that to do and would it hurt the tractor? Thanks Dan
Don Rudolph
04-19-2008 18:09:26
 Re: 430 Case in reply to Durkee, 04-19-2008 16:28:58
Dan,
It is true that the 430, 530 and 630 have the same 188 diesel engine. The difference is in fuel delivery and engine RPM-both determined in the injector pump. It is easy to change both settings if you want. I am running my 430 at 530 specs after rebuilding the engine and believe it will do no harm. I'm not sure if the driveline components are built for all the HP you can wring out of a 188 motor. It has always puzzled me why the 630 was such a dog sales wise as it is a nice sized chore tractor. I have heard that the 600B was a very unreliable model (driveline wise)and maybe that had something to do with poor sales of the 630. Don
tom stanley
04-22-2008 06:18:14
 Re: 430 Case in reply to Don Rudolph, 04-19-2008 18:09:26
I have a 600B and a 630COM Dsl have run them over 20 years and have never had a tranny problem of any kind also have at least 10 other COM no problems ever as a dealer if we had problems with a COM it was operator error or lack of service so of my units have over 10,000 hrs on them and except for oil changes no work done to them HEAT was about the only thing to destroy a COM
John Noname
04-20-2008 18:26:45
Don, I believe the dealers were also some of the cause of low sales. They talked against it because of the sleeves. My Dad and brother looked into one but Tom (dealer) talked against it.
