vac pto shaft
steven in tn
04-19-2008 13:08:29
third party image
does any one have or know where i can get a good used pto shaft for a vac case.
are all vac shafts the same? any other shafts the same? any way to fix this? shaft is wore out on the end where the bearing is.
Bill_Utah
04-19-2008 17:37:05
 Re: vac pto shaft in reply to steven in tn, 04-19-2008 13:08:29
Steven
I just parted out a VAC that has a good PTO drive unit that the shaft is good in it. If you don"t find a suitable solution Im sure I can help you out.
Bill
steven in tn
04-19-2008 17:21:47
sent u an email case v
TimBinWV
04-19-2008 17:15:48
Hi! I"ve got a "46/49? VAC with the pto still in it. Send me an offer for the shaft/as well as anything else you may need. Thanks!
case v
04-19-2008 15:37:17
send me a email tell you how to fix it
old
04-19-2008 14:19:31
A good machine shop could weld it up and then turn it back down but that might cost a lot. I have a VAC here for parts but don't know how good or bad the PTO shaft is since its still in the tractor. My e-mail is open if you want to know more
