Case LA water jacket leak
Jerry Custer
04-19-2008 09:40:19
The block froze on my late model LA. Outside is fine, however, coolant runs into the crankcase. Any suggestions of where the interior damage may be? Can it be repaired? How can it be repaired?
RobertTX
04-21-2008 05:58:35
 Re: Case LA water jacket leak in reply to Jerry Custer, 04-19-2008 09:40:19
LC Gray is correct. These blocks usually freeze break on the pushrod side. If you pull the valve cover and look down by the pushrods with a light you should be able to see the break.
L.C.Gray
04-20-2008 07:37:59
I've seen a few Case blocks that busted out the water jacket on the inside of the pushrod tunnels.
Thats where I'd be looking. You'd either need to pull the head or use a borescope up through the crankcase hand holes on the r/h side to confirm it.
C. Amick
04-19-2008 20:32:53
Are they wet sleeves? If so, could one of the rubber "O" rings be leaking instead of having a crack? If it is a minor leak, you might be able to stop it with "block sealer". It's available at auto parts stores. The treatment works with water, so you have to add the coolant back later. If this doesn't work, I would pull the oil pan off and see if you can tell where the leak is.
jay-eye-see
04-19-2008 12:54:00
I have a 48 LA that does the same thing , I welded on it with the sleeves out and still have a minor leak, ihc49 is prolly correct im sorry to say
ihc49
04-19-2008 10:15:11
it has to come apart before a decision can be made regarding frosen stuff. usually cheaper to change out blocks. than repairing cracks.
