SC Cylinder sleeve crack
OldIron
09-18-2006 14:02:41
Hello
I have an old SC that I"ve found a crack in one cylinder sleeve. At least I think it"s a sleeve. The clinder ridge cap appears to be steel while the block is cast. The leak was located when coolant started flowing out of the cylinder while running.
A couple questions:
Anyone know a good (i.e. cheap) source for individual sleeve/piston combos? (It"s more a toy than a "serious" restoration, so used would be preferable, though probably unrealistic)
I am guessing that to remove the sleeve a jack underneath with a bracket to the bottom of the jack so all force goes to the sleeve would work to remove old sleeve? Does anyone have a better/smarter/easier way of removing the sleeve? (Perhaps torch heat?)
Any additional advice, help or info about this project machine would be greatly appreciated.
OldIron
C. Amick
09-19-2006 09:50:51
 Re: SC Cylinder sleeve crack in reply to OldIron, 09-18-2006 14:02:41
The best way to remove a sleeve is with a sleeve puller. It has a bracket and a big nut that sits on top of the block and all-thread rod that goes down through the sleeve and mounts to a circular disc and nut on the bottom of the block. Used and new sleeves are available depending on which engine block you have and the size of your pistons. Get the block serial number off the edge of the flange where the bell housing connects (left side, I think). Get the part number off your piston.
