continental diesel engine
dave cote
04-17-2008 19:25:24
i have a case model 300 with a continental diesel engine, i cant fine a piston and sleeve kit for it. is it practical to swap the engine with a gas motor? thanks
Edpap
04-19-2008 20:21:01
 Re: continental diesel engine in reply to dave cote, 04-17-2008 19:25:24
Hello Dave,
I show a listing for parts for that engine but I would have to call monday to check if they have them. you can look up the parts yourself on my website. send me a email with what you need and I will check monday
Thanks Ed
John Saeli
04-19-2008 09:51:48
The sleeves can usually be salvaged by boring the inside & pressing a "Tin Can " Liner in. You can get creative w/ the Pistons by searching for a Piston of the correct bore & machining & bushing if needed to fit. We have a 389 Pontiac Piston purrin' away in a '54 Dodge Model "Y" Truck because I couldn't find a Piston anywhere. Searched US & Canada for 2 years.
Good Luck!! BTW, The Lord is coming back, but doubt he'll have them sleeves & pistons.
Don Livingston
04-18-2008 05:13:47
To find a new set of pistons and sleeves for a GD157 Cont, would be under the Good Lords arms on his second coming. Good luck, Don L.
El Toro
04-18-2008 04:20:39
Give this company a call at 1-800-922-5632 to see if they have a sleeve kit Hal
RN
04-18-2008 00:24:31
Happens - if tractor had both gas and diesel the parts are usually available for swap. IHC has an interesting situation with the 350D model- Continental diesel was about 4000 made, parts-especially engines or blocks- hard to get now while gas H, Super H, 300, 350 engines and utility equivalents are widely, reasonable cost available. Blown Continentals are replaced with the IHC gas engines often enough to confuse people wondering about TA on Hs. RN
