Chain drive S
Gary Covert
04-16-2008 09:32:03
When I'm in 4th and going downhill the chain drive sounds like a sloppy chain. Any other gear or in 4th when it is not free wheeling it sounds Ok. Is this normal or does the chain need to be tightened? Is there any way to verify the chain tension without removing the back plate? If it does need adjustment how do you slide the axle housing without tearing up the gasket?
Bruce Nelson
04-16-2008 17:26:47
 Re: Chain drive S in reply to Gary Covert, 04-16-2008 09:32:03
Gary, chain noise is not normal. If you can hear your chains, something is wrong. You can jack up a rear wheel and rock it back and forth (with the brake locked or the transmission in gear) to get an idea if a chain is loose or not. If you have slack in the chain, testing it this way, it is too loose. A properly tensioned chain will not allow very much, if any free movement at the wheel. How can you save the gasket? I cannot believe it will not just crumble if you slide the axle. Hard to say, the gasket could be original and 60 years or so old. Bruce
