early 1950's case dc
tooltime
04-15-2008 19:44:10
what is the horse power? and this tractor has hand crank start, mag. is a case dc a good work tractor. i think this tractor has a 3pt , but no live pto. and third arm for 3 pt is just above pto, so some impiments may not work. i guess i need some of your thoughts as i am new to case tractors. i own a farmall cub, 340 utility IH, AND a 8N ford.
tooltime
04-16-2008 15:26:20
 Re: early 1950's case dc in reply to tooltime, 04-15-2008 19:44:10
HI, Thanks for all your input, it sure helps. im new to tractor restoration, and have lots to learn. I Like the case tractor alot, heavey duty. this tractor has a serial number i think reads: 5401590DC does this sound right? thanks again, Jim
Tom Railsback
04-16-2008 15:33:10
 Re: early 1950's case dc in reply to tooltime, 04-16-2008 15:26:20
AS I had guessed, it does not have Eagle Hitch (built too early according to the serial number) so it does not have live pto.
tooltime
04-16-2008 16:17:18
 Re: early 1950's case dc in reply to Tom Railsback, 04-16-2008 15:33:10
is a case without live pto still a good tractor? i sure like the looks of it. live pto would be nice
Tom Railsback
04-15-2008 20:55:02
If it has the Eagle Hitch, it does have live PTO. If it has some type of added 3 point, it probably does not.
The serial number will tell us.
garytomaszewski
04-15-2008 20:10:01
The DC is way more tractor than any you list. If you have the "Eagle" hitch ( Case version of 3pt.) it is one of the later models.If serial number starts with a 5 subtract 4 from the first two numbers to give you the year, # is on the plate on the dash or on the engine by the air cleaner where engine bolts to the back end.
Alan Golden
04-15-2008 19:55:42
According to Nebraska Test #340, a DC had 35.51 hp.
hunter1
04-16-2008 02:59:11
 Re: early 1950's case dc in reply to Alan Golden, 04-15-2008 19:55:42
test 340 running at 1100 rpms
I would suppose one line of the test showed 35.51 but the test 340 showed observed hp at 33.06 drawbar and 35.36 belt and corrected hp of 34.08 drawbar and 38.62 belt on gasoline in 1940.
test 349 running at 1200 rpms
The distillate was observed 30.67 db and 35.28 belt - corrected 33.03 db and 37.45 belt.
The c's test in 1929 runing on kero - tested 28 and 29 on the belt observed - basically the same engine running I believe at 1,000 rpms. By the model year 1952 - the gas were in the 45 - 50 on the dyno - they were not tested at Nebraska the lpg model dyno'ed a little higher all seem to run at 1250 rpms under load and if turned up to 1400 - 1500 rpms the lpg would hit 60 on the dyno. Cannot remember the gas being dyno'ed at these higher rpms as we sold very few gasoline most were lpg's.
Don Rudolph
04-16-2008 08:43:02
 Re: early 1950's case dc in reply to hunter1, 04-16-2008 02:59:11
I am writing a book about Case dealers. May I ask where you were located and maybe some other questions about your dealership? Thanks, Don
garytomaszewski
04-16-2008 13:30:41
 Re: early 1950's case dc in reply to Don Rudolph, 04-16-2008 08:43:02
Don, Do you have any info on Linne Bros., Troy Grove, Il., brother worked for them. Family Case dealer from 20s til IH wanted new building, showroom, tractors on lot,etc..
Don Rudolph
04-16-2008 19:28:36
 Re: early 1950's case dc in reply to garytomaszewski, 04-16-2008 13:30:41
Gary,
In fact, I drove by their old place on Saturday on the way home from Mississippi just for a look see. You never know when you are driving past the location of an old Case dealer. Our local dealers building was torn down today-it was in very bad shape. The Case history is fading fast I'm afraid and IH doesn't much care. Thanks for the reply! Don
