Case 930 PTO question
Garyb31
04-15-2008 19:36:10
I have found a case 930 tractor for sale at a really good price. The only thing it does not have is a pto... which I would probably need for brush hogging and hay cutting. Is there a way to add a pto to this tractor, maybe powered off the hydraulics? Or maybe another way of brush hogging? Thanks.
DKase
04-16-2008 07:28:04
 Re: Case 930 PTO question in reply to Garyb31, 04-15-2008 19:36:10
I have an organ doner here in SD if it would help you out. If yours is a 6 speed. DK
SDLars
04-16-2008 06:05:03
Can we assume yours is a 6-speed, rear mount, chain drive, 60-62 model? If it is and you can find a donor tractor, it isn't hard to bolt it up to what you have. I assume also that it does have hydraulics?
bradley martin
04-16-2008 01:40:20
It would not be practical to power a PTO with the hydraulics on this tractor...not near enough capacity for the high power demand of bush hogging. The reason the tractor is so reasonably priced is likely because of the lack of PTO. PTO could be added if you had a donor tractor but it would be a major job.
