case 580k transaxle / gears
jeremy collard
04-14-2008 11:56:54
still struggling!
i think i must be having a dumb month, but to drain the trans oil is and where is the drain plug or is it just undo the suction screen and let rip!?
i have a case construction king 580k made in 1992. the shifter is located on the console on the right and i am struggling to secect gears, most of the time i can select 1st and 2nd but the others are a no no. this has happened before and i traced the fault to the cluth buttons. they were full of dirt causeing a high resistance and blowing the fuse. but the fuse is ok this time, im reasonably confident its not mechanical, if anyone can suggest something i would be very greatfull.
cheers
mEl
04-14-2008 18:15:04
 Re: case 580k transaxle / gears in reply to jeremy collard, 04-14-2008 11:56:54
Have you tried penetrating oil on the shifter shaft where it enters the trans case, I have had some rust tight there, use a good penetrant there and see if you can get it loose.If it is not seized there it is probably a mechanical issue. The drain plug is on the right SIDE of the transaxle toward the front, not on the bottom.
