dc oil seal
johndeereman
04-13-2008 16:48:44
my dc's front cranckshaft seal is leaking im wondering if you have to take the front end off to change or is there another way also does anyone know the number of that seal?
mEl
04-13-2008 18:25:41
 Re: dc oil seal in reply to johndeereman, 04-13-2008 16:48:44
JD man, The DC uses a big felt to seal the crank on front, there is a lock wire that keeps the bolts from backing out as the bolts were not tightened, only enough to slightly compress the felt, cut and remove the lock wire from the bolt heads, tighten the bolts a bit and see if that helps. The cover has a inward slope and the retainer has an outward one to give a compression inward toward the shaft as the bolts are tightened. New seals are not available from Case. I may build a precision seal retainer for a modern seal for my resto project that I am presently involved in. good luck. mEl
Ken in AZ
04-14-2008 07:06:17
 Re: dc oil seal in reply to mEl, 04-13-2008 18:25:41
John Saeli has the felt available; I got a set for the DH I'm rebuilding. I also got a full set of seals for the transmission so it doesn't leak when I finally get her back together. I found that one of the seals (PTO shaft, IIRC) fits nicely into the seal for the crank snout. I used a touch of "the Right Stuff" (smeared some on with a finger) where the seal touched the housing. It fit like it was made for the application. This is a new neoprene seal from SKF, if I recall. Don't know if it works properly yet though since I am still slowly putting everything back together. I don't have the tank on it and I still need to go get the right front axle for it.
Ken in AZ
