Case VAC Clutch
Charlie North
04-13-2008 12:32:13
Hi all
I finally broke my 1949 Case VAC tractor in half to fix the clutch.
It went well except I cannot figure out how to remove the clutch release bearing and/or the clutch release yoke.
It appears from the parts schematics that the yoke is retained by a 3/8" nut but I sure can"t see it.
Anyone been there to advise me how it is done?
I also wonder if it is recommended to replace the pilot bushing along with the clutch, pressure plate and throwout bearing?
Thanks
Charlie North
04-14-2008 11:29:55
 Re: Case VAC Clutch in reply to Charlie North, 04-13-2008 12:32:13
Thanks olddog. It is clear now. I had even noticed the flats on the standoff stud and it shows a lockwasher in the schematic! I am ashamed to admit that for some reason it didn't occur to me to unscrew it from the bellhousing.
I'll follow your advice jal-SD. I was however happily suprised that splitting the tractor wasn't a big deal.
olddog
04-14-2008 05:42:24
Imagine the clutch release arm stud as a ball/socket. The standoff stud unscrews from the front of the bell housing and comes off with the yoke arm and bearing.
jal-SD
04-13-2008 14:52:40
Yes, you need to replace the pilot bushing, they always need to come out when you are in there. The relatively small cost of a bushing is nothing compared to the cost and the trouble to take it apart again. If its even just a little wore or rough, it'll make a lot of undesirable noises when you have done all the other work. (My $0.02 worth. jal-SD)
Charlie North
04-25-2008 18:22:45
 Re: Case VAC Clutch in reply to jal-SD, 04-13-2008 14:52:40
Darn It
I cannot find the bushing.
I ordered all the rest of the parts from Yesterdays Tractors.
I don't know what this Yesterdays Tractors item is? Pilot Bearing - For Model: VAC. (Part No: 508051)
Can anyone offer some help finding the bushing?
Thank You
