Hydraulic Oil Filler Tube
Scott L
04-12-2008 21:03:24
I don't have the manual for my Case Int'l 385 tractor yet. Can anyone tell me where the filler tube is to add hydraulic fluid? Thanks.
Charles Hinton
04-13-2008 05:44:09
 Re: Hydraulic Oil Filler Tube in reply to Scott L, 04-12-2008 21:03:24
It's at the rear of the tractor directly above the PTO shaft - no tube, just a rather pipe plug. The dip stick to check it is on the left side - that checks the hyd system, rear end, and transmission. All three of these components use the same fluid - HyTran, around $50.00/5 gal.
Scott L
04-13-2008 20:45:19
 Re: Hydraulic Oil Filler Tube in reply to Charles Hinton, 04-13-2008 05:44:09
Charles: Thanks so much for the quick reply. I'll check it out tomorrow.
