vac pto
steven in TN
04-12-2008 17:00:20
i need to replace the pto seal and bearing. are these the right numbers to replace with seal cr 13738
bearing 14137a
race 14276
do i have to pull the whole pto out to replace the bearing close to the seal
C. Amick
04-14-2008 08:59:55
 Re: vac pto in reply to steven in TN, 04-12-2008 17:00:20
The Chicago Rawhide Number I have for the seaql is: CR13739 or the National Number is: 473215.
olddog
04-13-2008 06:10:44
Yeah, it's gotta come out, the bearing, gear and inner bearing are all held with a nut on the inside end of the shaft. The seal is in it's own quill on the outside. Not a bad job, actually, the worst part probably draining the oil.
