rear rim for 1957 case 320
e. chrisjensen
04-11-2008 20:32:19
I"m looking for a rear rim for a 1957 case 320 6 bolt pattern: 14.9-24/13-24 tires
Bill64
04-13-2008 09:13:20
 Re: rear rim for 1957 case 320 in reply to e. chrisjensen, 04-11-2008 20:32:19
If you have the one piece rim like I have on my 310 Utility this is what I did to replace the rusted one. Bought a 24x12 outer rim ring from M.E. Miller tire. Cut the center out of the old rim and welded it into the new ring. Works and looks like a new wheel. the only difference is that my original wheel was 11" wide. The new rings only come in 10 or 12" widths. Miller suggested the 12 and that's what I used.Hope this helps.
Bill
VACLee
04-12-2008 10:02:36
I am assuming you have the one piece wheel/rim. They used a two piece on the 310. With that center yo can use a regular 4 loop rim. I have that setup on my 310, and I have some extra centers. They were used on several other tractors besides Case.
TimBinWV
04-12-2008 06:02:41
Me,too! Plus a set of good used tires...
TimBinWV
04-12-2008 06:05:39
 Re: rear rim for 1957 case 320 in reply to TimBinWV, 04-12-2008 06:02:41
I've actually considered changing the rear industrial axles to AG axles so I can use the more plentiful 8 lug rim,and 28" tires...anybody ever done that?
