cc brake drum/bearing, PTO gear
mshultz
04-11-2008 18:26:36
Working on a new to me CC rearend. Put new brake lining in it, had adjusting screws made for it, and when I push on the left brake the drum moves just a bit. I thought maybe the drum was just loose. I have the top cover off, so I looked in and noticed that the entire shaft apparently is moving. I assume the bearing must be going out. What all is involved with changing this bearing?
Also, I"m hoping to put the flat back on it from my C, but I"d like to be able to have the option to put the PTO in w/out splitting the tractor if that"s possible. Can I leave the PTO gear on the tractor that runs constantly off of the input shaft if I remove everything else that goes to the PTO. I realize I"ll still have to remove the top cover to put it back in and I"m willing to do that once in a while. But from the way I see it I"d have to split it to get that top gear off and that"s more than I"m interested in doing just to put it on the dyno every once in a while (or can you do this through the clutch access holes if needed??)
Thanks for any help on this. I can"t believe how heavy the gears and shafts are in these things - easily 2-3 times the size of our Farmall H gears and shafts. The load is applied differently which I"m sure is part of the reason, but they"re still huge to me!
mEl
04-12-2008 04:15:11
 Re: cc brake drum/bearing, PTO gear in reply to mshultz, 04-11-2008 18:26:36
Mike , give me a call if you like, Tom, the cc-early dc drum brake uses a spur gear that drives off the diff shaft and is mounted above it. Mike I believe the housing has a bushing to carry the brake shaft. The PTO sadly, you will have to remove and reinstall the top each time that you remove or reinstall the pto shaft as the pto drive gear is carried by the shaft and idles on it when not in use, there are spacers and a drive coupler that slides on the pto shaft to engage. The front bearing cover can be reinstalled after the bearing is removed. I will be available today via cell, you have my number, I have a complete PTO from a flat back that we removed from our puller, if you need it maybe I could convince Terry to sell it, if you need parts??? mEl
Tom Railsback
04-11-2008 18:47:50
Mike:
The brake drum is on the outer end of the differential shaft so it will have some movement.
I don't see why you could not leave the gear on the input shaft. You should be able to reinstall and remove the PTO by taking the top cover off and working though the clutch handhole. As I recall the bearing would sit in its race without causing any problem.
