SC Gear shift
DGK
04-11-2008 17:21:04
Hi Just brought home today, they told me starter was bad but flywheel ring gear missing teeth. Also gear shift lever is stuck in 4th gear. Pulled gear shif out but still can't move anything in trans. Nothing looks rusty, any sugedtions. Thanks Doug
C. Amick
04-11-2008 18:20:07
 Re: SC Gear shift in reply to DGK, 04-11-2008 17:21:04
Are the brakes free? May want to loosen the housings. It's not unusual for the brake discs to stick when sitting. Is the clutch fully released? Does the motor turn independent of the transmission?
DGK
04-12-2008 06:24:43
 Re: SC Gear shift in reply to C. Amick, 04-11-2008 18:20:07
you were right,brake stuck, works now THANKS
