hard to start 1030
old buzzard
04-10-2008 16:04:21
im looking at buying a 1030 with a diesel. it has set for a while 6 months or so. it dont seem to have blowby and seems tight. but to start it on a 60 degree day we had to give it a shot of either. could it just been setting to long-bad injector, or something else kinda simple or could it be deeper. i do under stand this is kinda vauge, im just tryin to get an idea
thanks
KY Jim
05-08-2008 01:03:37
 Re: hard to start 1030 in reply to old buzzard, 04-10-2008 16:04:21
That looks like my 931, only yours has a cab. I had the same problem, didn"t take the starter long to die, had it rebuilt, now engine SLOWS DOWN after it lights, on one battery. Before starter died, changed out the fuel filters, helped A LOT. New heavy cables helped even more. Go over it, replace Factory 40 year old stuff with new, all the little things together WILL Add Up. Starter had bad armature, cost about 150 for rebuild, incl. armature, solenoid, and brushes. KY Jim
John Saeli
04-12-2008 17:25:55
Even after sitting, with gravity fuel feed, the 1030 should start @ 60 without help. KEEP THE ETHER AWAY!! You will crack heads or sleeves.. My experience with any Case Power Cell Diesel is that with good batteries, cables, and in proper tune, they will start. Our 730 will start quickly @ 32 degrees without manifold heat. Never grind the valves & seats on any diesel, replace them. Mill the head. 1,000 CCA Batteries @ 0 degrees F & heavy cables.
1030 Brian
04-12-2008 13:40:08
Did you use the manifold heater? Even on a warm day it doesn't hurt to use it for 20-30 seconds. I never have used ether on ours. If I want to start it in the winter just plug in the block heater. Good luck!! -Brian
old buzzard
04-11-2008 10:43:50
guy's thanks for all the advice. i took her a spin today and noticed that it turned over a little slow (batt. or starter)run good ect. so the ole girl is mine now
thanks again
Scott in SF
04-12-2008 08:28:45
 Re: hard to start 1030 in reply to old buzzard, 04-11-2008 10:43:50
That tractor is 40 plus years old and normal wear could leave it with a little compression problem, contributing to cold starting problems. 1030s were known for a few things, being cold blooded is one. They are also known for sipping fuel, running forever and being loud. I suggest you by several cans of either, earplugs in bulk and prepare for a rebuild in anouther 40 or so years. You are going to love that tractor.
Moline_guy
04-10-2008 19:54:58
third party image
Dads 1030 was always a little cold blooded, like others say, clean your fuel filters, clean up your cables and if its not spinning fast, maybe consider a starter rebuild. We usually just gave a small shot of either in the pre cleaner and it would fire up. One thing to look out for is comression in the radiator, usually a sign of sleeves starting to leak. Block must be machined before new sleeves can be put in or it will crack the new sleeves, don't ask me how i know. For the most part a good all around tractor, good horsepower, cheap on fuel, big but not too big. Good luck with it, there arent that many around for sale.
rexhellwig
04-12-2008 16:02:31
 Re: hard to start 1030 in reply to Moline_guy, 04-10-2008 19:54:58
Those things were the Cadillac of tractors back in their day.
And I wouldn't worry too much about the first start of the day being a little slow and smokey. That's just the way it is with the old power-cell diesels.
cahess
04-10-2008 19:24:04
Would not worry about that if it idles smooth - runs fine when hot. Might want to check starter- cables an if proper batteries are in. Starter needs to spin engine fast enough to start. Remember some of these things might be 40 years old (cables).An finally a very small sniff of ether will do trick .
garytomaszewski
04-10-2008 19:18:53
Could have been fuel filter waxed up,from fuel over winter,air in lines from 6 months, maybe rust in cylinders so the starter wasn't up to speed, diesel grows fungus with condensation from 6months no run. Put a new fuel filter on, fresh fuel in tank, prime then start and run see if use helps before starting to worry about fixing something that MAY NOT be broke.
