backhoe 580B removing nut on end of crankshaft
Shawn Popkie
04-10-2008 14:10:57
How do you remove the nut holding the crank shaft pulley on. I've tried impact wrench, does not work I have been told it is a left hand thread. Is it? How much heat can I put on this nut to loosen it? I need to change forward seal, and need to remove this nut.
mEl
04-10-2008 14:36:04
 Re: backhoe 580B removing nut on end of crankshaft in reply to Shawn Popkie, 04-10-2008 14:10:57
Whoever told you it is LH thread should stick to their occupation which definately is not a Case mechanic!! You can heat it if you have to but this is rare, a good impact wrench will usually remove them, but not if you are going the wrong way, it is RH thread.
