case 430 clutch
roy101
04-10-2008 11:52:40
tractor started grinding when i would put it in foward or reverse i adjusted the clutch now it either has no pulling power when i let out the clutch or if i adjust it grinds.
Larry59
04-10-2008 14:40:16
 Re: case 430 clutch in reply to roy101, 04-10-2008 11:52:40
Sounds like the clutch is gone. The revets in the clutch are draging and cuting into the flywheel. Just had same problem on my case. Had to replace clutch and throw out-bearing and have the flywheel turned or cleaned up.
If you cut that flywheel up to much. You will be looking for one again.
