300 Clutch Fork
Richard (KS)
04-10-2008 09:12:31
A friend has a 300 Case gas, serial 6053795, and he needs a good used clutch release fork. Anyone know where we could find one? Thanks in advance.
JamesPollard
05-08-2008 17:42:09
 Re: 300 Clutch Fork in reply to Richard (KS), 04-10-2008 09:12:31
hello depending on whats wrong with your friends clutch fork it may be repairable. I have a 420bd and the throwout bearing chewed thru the fork. Case wanted 130.00 just for the fork. I cut the fork and welded 1/2 in key stock on to it. Leaving the outside of the fork and as much of the worn part as possible for more places to weld. cut radius with torch and then ground and buffed to a mirror finish. Used outside of fork as reference for radius . I welded a large thick flat washer to the throwout bearing cause it was also worn. Saved a bundle.
Larry59
04-10-2008 09:20:07
You might check with www.caseih.com and follow threw till you get to parts. Sometimes they can get stuff for it. He can also find a complete brake down diagrams of parts for his tractor.
