401 injector pump
Scott KY
04-10-2008 09:07:02
I found fuel in the crankcase of my 401 yesterday. I assume a faulty seal in the injection pump is causing it. Does anybody have the part # for the seal behind the drive gear?
Doc Larry
04-11-2008 01:03:09
 Re: 401 injector pump in reply to Scott KY, 04-10-2008 09:07:02
If you go to your Am. Bosch dealer with your pump number he should be able to get the seal for you.
Jim McVay
04-10-2008 09:27:37
I think they are pressure by-pass lubricated so it would be an internal leak causing the problem or the supply pump is leaking.
