Fuel tank
jh
04-09-2008 18:31:42
The lower drain pitcock is leaking diesel the thing that the pitcock screws into that is made on to the tank anyone ever messed with any of them just a little help an info needed thanks Jay
mEl
04-10-2008 18:05:25
 Re: Fuel tank in reply to jh, 04-09-2008 18:31:42
If it is not leaking around the threads I would suspect that the nut is broken loose in the water trap, will probably require a removal, thorough cleaning and a silver solder repair.
jh
04-10-2008 18:17:26
 Re: Fuel tank in reply to mEl, 04-10-2008 18:05:25
i think my nut is broke loose how would i get th at thing out
mEl
04-10-2008 03:52:38
What make and model of tractor do you have?
jh
04-10-2008 17:56:19
 Re: Fuel tank in reply to mEl, 04-10-2008 03:52:38
Its a 900b the water drain thing in the tank is what i was talkin about not the pitcock the little Nut that the pitcock screws into also this is the little thing that hangs down on the right side of the tank
