Hey, Thad
jim handke
04-09-2008 05:34:25
Figured everything out when we assembled this 1175 engine. Found out it's out of a 1370. The casting number on the block, just above the dipstick, was the same as my 1070. That's what threw me off, I figured the block was a 451. Since the 70 series came out, this is only the second engine we have found that spun bearings. Put a guage in the block and it shows 40 lbs. oil pressure at idle, should eliminate the pump as the culprit.
Thad
04-09-2008 06:50:33
 Re: Hey, Thad in reply to jim handke, 04-09-2008 05:34:25
Glad to hear you got it running should be a stout 1175. I should have told you about the block number. At the end of the cast in number is a square box with a number stamped in it. Thats the number that will tell you what it actually is from. The 1070 number is A5851 and 3 in the square. The 1370 should be A5851 and 5 in the square. Thad
jim handke
04-10-2008 11:35:42
 Re: Hey, Thad in reply to Thad, 04-09-2008 06:50:33
That was another thing that threw me off. Our 2470 parts book showed the casting number started with a 6 A6. Figured all 504's would have that number. A big thank you for all your help.
