case SC wont keep running
Rick Wozniak
04-08-2008 14:03:43
Hi, I bought a 1949 Case SC that was converted to 12 volt. It starts and runs great but shuts down after a few minutes. Wait a minute and it fires and runs good for a couple minutes and shuts down. You can repeat this all day. It was converted before I bought it to 12 volt. I was told by someone I need to upgrade the coil to 12 volt, but I thought it had a magneto? Does it have a coil too. Anyone have any Ideas? I dont have a clue.
ralston
04-10-2008 05:43:17
 Re: case SC wont keep running in reply to Rick Wozniak, 04-08-2008 14:03:43
I would checkthe float level in the carbureter if its is adjusted to low it could shut the fuel off to soon.
Rick Wozniak
04-09-2008 11:09:00
I have some good ideas of what to do now. I sort of suspected a fuel problem but you have all confirmed it . Thanks very much to all who responded. Ill let you know how it works out. Thanks again. Sincerely Richard Wozniak
J hweitkemper
04-08-2008 21:23:44
use everyones advice,,got another to watch for allthough I doubt if this is Your problem today ,,SC manifolds are Notorious for Burning out and Sharing intake and Exhaust GASES,, Usually SHOWS ITS UGLY HEAD by Missing on the End Cylindars ,, They Are repaiable
todd hamilton
04-08-2008 17:33:10
I used to have a '44 SC and you want to watch for clogs where the fuel sediment bowl mounts to the gas tank flange. Crud can wash into the circular opening and restrict the fuel flow. Also make sure your point gap is not set too narrow. Mine had a distributor but did not run well if the gap was less than .018. BTW guys, don't crack jokes on the Farmall board - not much of a sense of humor over there. I probably need to buy another Case.
garytomaszewski
04-08-2008 16:40:15
Be a good idea to know what you have. Magneto does not care about 6 or 12 volts since there is no connection to battery. Does it run with choke on? Sounds a lot like fuel not filling carb fast enough when running. Open carb drain and turn on fuel should get a strong steady flow, close drain and take out load needle should also have steady flow. BEFORE you decide to fix??? carb go backward thru fuel system (connection to carb, connection to sediment bowl, glass off sediment bowl) and make sure there is a strong steady(5minutes) flow at each place. IF you have good flow try plumbing in at the carb with a gallon or so of E-85 and carb cleaner, if this doesn't clean it THEN rebuild carb.
old
04-08-2008 14:39:49
Clogged fuel system would cause that or a bad condenser. Pull the drain plug out of the bottom of the carb and make sure you have a good steady flow of gas for 5 plus minutes. Catch the gas and look at it to see if it has dirt/rust in it. If you don't get a good flow work you way back to the tank to find where the flow stops
HW
04-08-2008 14:15:59
See if the vent in the gas cap is open.
GaryDrz
04-08-2008 15:37:00
 Re: case SC wont keep running in reply to HW, 04-08-2008 14:15:59
I believe that you should take the sediment bowl off, and clean it out, as well as the very fine screen above the bowl. I have had them get get clogged up. Use a good carb cleaner spray, don't wreck the gasket, and I think it will purr like a kitten.
