Case International 585 tractor
PhilipT
04-08-2008 09:36:27
I have a 585 Case International, old but only about 2000 hours. It is getting water in the oil and it is burping not blowing oil out the dipstick tube. Please reply with what could cause this.
Antonio Callegarin
04-11-2008 10:44:49
 Re: Case International 585 tractor in reply to PhilipT, 04-08-2008 09:36:27
I am italian, I have a Case International 585 that consumes about one liter water per 4 hours. I don't know if this is normal. The function of the motor is good, the motor oil has a good color. I hope some expert will give you the right answer for the water leakage in the motor oil, and I ask you to let me know it when you will know.
The only hard failure my tractor had during the work, was an istantaneous lock of the speed gear control. The motor was running regularly, but the Case 585 could not move. A good generic tractors technician adjusted at low cost the gear control without the complete dismounting of the gear case, but sumply removing and greasing the gear external leverage.
Good work to you. Antonio Callegarin
