waterpump on 1948 Case VA
john92371
04-08-2008 08:48:21
I just recieve a waterpump for my case va and it looks the same except this one has the fan hub already mounted and mine has a keyed shaft that an adjustable pulley mounts to with a nut and then the fan mounts to the pulley. The tractor parts house says they dont have what I need. Anyone know where I might find the right pump or a different pulley that I can use?
john92371
04-08-2008 18:35:21
 Re: waterpump on 1948 Case VA in reply to john92371, 04-08-2008 08:48:21
After more research I found that the difference is that my water pump is for the case that came with generator and the one I bought is for without. If I can"t find the right style pump then I need to find the other pulley Case# VT-4549
Kevin Meier
04-08-2008 13:59:46
I can probably rebuild your old one if you are interested shoot me an email.
