govenor 530 case
sam un on
04-08-2008 06:05:48
in the midst of doing work on my 530 gas the 2 springs that are on the linkage behind the generator got tossed and although i did get 2 about the same i really am not sure as to how they attach or the proper tension that they should have . i really have no idea how the smaller spring attaches so what i need is an idea as to how they attach and the proper adjustment .. thank you sam
dbock
04-11-2008 16:20:33
 Re: govenor 530 case in reply to sam un on, 04-08-2008 06:05:48
If I remember correctly, the smaller spring goes inside the larger spring and they hook into the same place.
sam un on
04-09-2008 08:36:03
fanrastic, i see that the larger spring hooks into the 2 closest holes and am i correct in assuming that the smaller one hooks in one of the same holes with the other end hooking at #17 on the diagram. thank you so much for your help sam
JRT
04-08-2008 20:02:58
If I were you I would keep looking for some original Case springs for a 530. Did you check with a Case/international dealership? If you do not have exactly the right tension the governor will not act right. They are very sensitive and the right tension means everything.
Den N Ms
04-08-2008 19:31:43
third party image
Sam the small spring goes inside the big one.
sam un on
04-08-2008 09:50:51
i finally found some info as to how to set up the govenor, but unfortunately no info as to the correct placement of the 2 springs . any help is appreciated sam
