Steering Box
MaverickLatino
04-07-2008 13:35:05
I have a 50 - 54 Case VHA (?) tractor and need a part(s) for my steering box. The part that I am looking for looks to be for steering play adjustment. It has several holes on the front of the hollow shaft and is appx 10" long.Mine broke in half and the front adjuster is broken as well. I need to find one and what it is called, PLEASE email me asap:[email protected]
Jerry W
04-10-2008 16:20:09
 sector box in reply to MaverickLatino, 04-07-2008 13:35:05
I have an empty steering sector box with this part in it that I would sell for $20 + shipping. I don't care to try to remove it. It (the sleeve) has some pretty deep pitting from laying down in gunk inside the bolster but I think it is solid yet. If you are interested I could send some photos.
Jerry
MaverickLatino
04-10-2008 18:03:04
 Re: sector box in reply to Jerry W, 04-10-2008 16:20:09
yes please send me some photos if you would. can you send them to me at this email address:
[email protected].
i am very intersted in the part if it is the same one. So long as it is not broken, I am sure that it is better than mine which has sheared in two pieces and the adjustment plate on the front is also broken.
Where are you located and how much do think the freight would be. If you can see the part number on the sleeve, it would be VTA3074. If you need me to send you a diagram of the assembly, i have that available as well.
thanks you very much for your reply.
Larry59
04-07-2008 17:02:45
 Re: Steering Box in reply to MaverickLatino, 04-07-2008 13:35:05
Go to www.caseih.com and follow threw till you get to parts. They will have pictures and diagram so you can see what you need. They might even have it. No matter you can see what you are needing.
MaverickLatino
04-07-2008 17:58:00
 Re: Steering Box in reply to Larry59, 04-07-2008 17:02:45
THANKS FOR THE REFERENCE. THE PARTS ARE NO LONGER AVAILABLE FROM A DEALER. DO YOU KNOW OF ANYONE WHO MIGHT SELL USED PARTS YOU CAN REFER ME TO?
I NOW KNOW THAT MY TRACTOR IS THE LATE 1951 AND THE STEERING WAS CHANGED FROM THE EARLY 1951. THE PART NUMBER I NEED IS VTA3074. IT IS THE SLEEVE, STEERING WORM AND SHAFT. THE PART I NEED ADJUSTS THE CLEARANCE BETWEEN THE WORM AND WORM WHEEL WHICH ADUSTS THE END PLAY.
CAN ANYONE HELP ME WITH THIS PART? COME ON TEAM.
