ID Number
rfowler
04-05-2008 15:35:20
I just bought a Case 530 gas powered tractor with front end loaded. I see on ID tag on the side of the loader which says Model 31 followed by a number (no identifier), I am guessing its for the loader and not the tractor. Does anyone have an idea wher I can find the ID Number fr the tractor? I hav no idea what year it is and I need to order some parts for it. Thanks!
dsundy
04-14-2008 10:08:53
 Re: ID Number in reply to rfowler, 04-05-2008 15:35:20
third party image
I had the same issue on this 530. The tractor S/N tag was missing but I still had the loader S/N and the engine S/N tags. I went through the online parts books at caseIH and was able to narrow down the S/N by comparing what I had with the pictures in the books. Good luck.
Dan
TimBinWV
04-06-2008 04:59:16
If the id tag has been removed,there will be two small holes on the left,outside flange of the dash housing. It's possible that it could have been to the right of the wheel,on the face of the dash,lower down.
Larry59
04-05-2008 20:09:36
The number you found is for the loader only. I have a 311 case. My number is on left side of insturment dash. Perhaps this will help. Small retangle with two rivets or screws on each side of ID.
rfowler
04-05-2008 20:20:26
 Re: ID Number in reply to Larry59, 04-05-2008 20:09:36
Thanks for the information, I will look for it there. Are there any numbers stamped into the frame? It seems as tags are lost or removed, thus loosing all information. I don't remember seeing one (took panel off today to remove tank) there. Lets hope its just my poor memory. Thanks again for your help.
