Removing 3020 Oil Pan
Greg Hall
04-05-2008 14:28:35
I need to remove oil pan on my JD 3020 to look at the crank. How do you remove the cone shaped piece that the oil filter is pressed against. I thought it had a nut on the shaft but does not, looks like maybe the shaft has 3 tabs that are bent down around the cone. Any advice?
Greg Hall
04-08-2008 05:45:10
 Re: Removing 3020 Oil Pan in reply to Greg Hall, 04-05-2008 14:28:35
Thanks for the replys...I got it.
cnj152
04-06-2008 06:08:35
The cone you speak of is part of the oil pump and does not have to be removed to get the pan off. The cylinder where the oil filter goes is removed as the other post said. Hope this helps
Tom (Ks)
04-05-2008 15:17:17
I do not understand what you are talking about. You remove the four nuts and the filter cap comes off. Then, remoce two nuts that hold the can against the side of the pan. There are six bolts that go into the clutch housing plus all of the pan bolts. After the pan is off, there is a balancer and the oil pump in there that you might have to take off if you want to see that part. There are locking tangs on those bolts. Take a hammer and screwdriver and bend these away from the heads and remove the bolts. You will have to time up the pump and balancer when you put them back in there.
