580 ck
DALE HINTHORN
04-05-2008 14:21:57
i have a transmittion problem . if you start the tractor it will drive away by its self even when it in neutral. it will not go into reverse. it was purchased not running and don't know if the problem existed before the engine was overhauled. have done the linkage check and so on and it looks ok any help please. it a 70's model tractor no loader or backhoe.
tom stanley
04-05-2008 15:20:17
 Re: 580 ck in reply to DALE HINTHORN, 04-05-2008 14:21:57
need more info is it a power shuttle? if it is I have seen this once problem was clutch in fwd-rev unit was welded together found operator to be using the clutch pedal as a foot rest which was starving the system of lube and press
DALE HINTHORN
04-06-2008 05:46:09
 Re: 580 ck in reply to tom stanley, 04-05-2008 15:20:17
yes its a shuttle shift. could it be in the valve that shifts it from forward to reverse?
