540 PTO turning 1000 pto speed in a 1175
Loren Anderson
04-05-2008 13:26:06
My 1175 has the reversible shaft for 540 and 1000 splines, after i had used the 1000 pto on a hayconditioner, i switched the shaft back to 540 for use on a smaller haybind, at this time i realized that my pto was still turning at the 1000 pto speed as the Haybind almost flew apart any suggestions or solutions to my problem would be appreciated! Thanks!
mEl
04-05-2008 13:52:24
 Re: 540 PTO turning 1000 pto speed in a 1175 in reply to Loren Anderson, 04-05-2008 13:26:06
Sounds like the spring loaded sliding sleeve may be a bit sticky and the gear stayed in the 1000 rpm side even though you changed the shaft. Take the shaft out and treat the inside with PB Blaster or another good penetrating oil and see if the sleeve will come loose , put the shaft back in in the 1000 rpm position and bump with a block of wood to jar it , do not hit it hard as you could damage the internal shift pins. Just enough force to shock it a bit. Possibly the pins have broken or come out of place as this occasionally happens as do broken shafts buts lets work on the assumption that its just a bit rusty for now. If it won"t come loose we may have to dig deeper. mEl
tom stanley
04-05-2008 15:14:22
 Re: 540 PTO turning 1000 pto speed in a 1175 in reply to mEl, 04-05-2008 13:52:24
that is the reason I try to keep the shaft clean and lubed when it is changed give mine a good coat of gun grease when changing
