Removing Oil Pan
ktrottier
04-05-2008 12:32:45
I have a 68 680BCk with a A267D diesel engine. I am doing an in-frame rebuild and need some recommendations on removing the oil pan. Looks like I have to pull the front motor mount to get the pan to clear. Any one ever do this?? Thanks for the help.
El Toro
04-06-2008 09:11:29
 Re: Removing Oil Pan in reply to ktrottier, 04-05-2008 12:32:45
You should get a good shop manual to cover that vehicle. My co-worker lost oil pressure on his 1962 Ford car and by luck he had the shop manual
that gave the procedure for pulling the pan. We had to unbolt one side of the oil pump to get the pan off and swing the pump around. We installed a new pump, but had to leave out one of the bolts until the pan was in position then reach in there and to tighten the bolts. We primed the pump too before installing. The relief valve was stuck open on the old pump. It probably would have been ok to reinstall. Hal
