case cross motor
stewartinpa
04-04-2008 16:15:09
I found a case cross motor in a barn partly taken apart and stuck it is all there the owner wants $8,000 for it is that way to high I was thinking a $1,000 but I know it is rare
give me some thoughts
Stewart
Dave Olson
04-06-2008 13:46:32
 Re: case cross motor in reply to stewartinpa, 04-04-2008 16:15:09
Hello Stewart,
Click the link below. It will take you to a value guide that was published in 2001. You will need to scroll down to the 10-18.
In the first part of the book they explain their rating system.
Remember using this you need to keep in mind 2001 values. Pick the rating for the tractor in question and then add how much you think values have gone up since then!
Dave Olson - East-Central Illinois
STEWARTINPA
04-05-2008 06:21:51
The owner said it was either a 9-18 or a 10-18
Glenn/Mn
04-05-2008 07:37:49
 Re: case cross motor in reply to STEWARTINPA, 04-05-2008 06:21:51
There is a big difference in value between the two get me the serial number and I can tell you more, the engine design, parts availability is different as well
STEWARTINPA
04-06-2008 02:15:22
 Re: case cross motor in reply to Glenn/Mn, 04-05-2008 07:37:49
I looked it is a 10-18
Glenn/Mn
04-06-2008 06:10:37
 Re: case cross motor in reply to STEWARTINPA, 04-06-2008 02:15:22
I have several listed prices being sold at auction they are low $4600-$5400 next step being restored $12,500-$15,400 since the tractor is apart you have the opportunity to look at how the gears are and maybe to see how it spent it life, either on the belt or in the field pulling something, only you can decide what it is worth and what is needed to get it going, one sold yesterday in Neb but I have no information to give you on that sale yet, maybe someone that saw it sell will chime in. A special serial number or different tractor accessories will change the value. Good Luck!!
STEWARTINPA
04-05-2008 01:47:31
I will try to find out the model today
Glenn/Mn
04-04-2008 17:14:25
Model?
