case730 diesel case o matic
Rob Moritz
04-03-2008 17:44:04
Hi I am looking to buy a 730 case diesel and would like all the info i can get about it such as the feul use power starting in cold wether and so on and the bad will it hold up to heavy work with a loader is the moter reliable and the hyd and the trans thanks for the help
John Saeli
04-04-2008 14:15:55
 Re: case730 diesel case o matic in reply to Rob Moritz, 04-03-2008 17:44:04
If it's a "Draft O Matic" it has a great hydraulic system well suited for a loader. If it's an older Eagle Hitch style, pump parts are either not available, or very expensive, and not as good a system as the new D-O-M's. The diesel engines are very economical & well built, but for real cold weather, need to be plugged in. Ether will do damage in short order.
