what have we got?
jim handke
04-02-2008 17:04:03
A friend brought in a yellow 1175. # 3 rod bearing had spun and ruined the crank, # 4 bearing had scuffed up the rod. When he goes to get the crank and used rods, he was told the rods were out of a 504. I checked the block number and it's a 451. Checked the piston and it measures just a hair over 4.5 inches. Our parts books show a 451 at 4 3/8 diameter and a 504 at 4 5/8 diameter. The part number stamped on the piston is A146697. Is this an engine out of a loader or dozer? We've never run into anything like this.
Thad
04-03-2008 05:29:03
 Re: what have we got? in reply to jim handke, 04-02-2008 17:04:03
Sounds like you have a 504 in it. The # on the piston is for the large journal 504 engine. The pin size in the piston should be 1.800 if it is the large journal 504. As far as the tag saying 451 i have seen a 870 that is taged with a 267 tag. But when i checked the casting # on the block it actually had the 336 in it. So the best thing to do is check that # to tell you which engine is in it for sure. There are several other ways to tell also. Hope this helps Thad
