S/N Model # Mis-match
james Hurt
04-01-2008 12:54:10
The plate on the right side of the frame reads as s/n 8327977 but the Model # reads as 540. Case dealer says there was no Model 540, but that the s/n falls within the Model 530 group for tractors built in/around 1967.
JICase
04-01-2008 19:06:19
 Re: S/N Model # Mis-match in reply to james Hurt, 04-01-2008 12:54:10
He's correct on the serial number for 1967.
530 on the decal means its a 530 alright, but which variation do you have?
Thats where the numbers on the tag come into play.
When ordering parts your dealer needs to know that the model number on the tag tells him what variation of engine, transmission and axles it has.
If he don't know, you need to educate him or he'll order the wrong stuff every time.
540 on the tag tells him what you have and these numbers sort it all out if he's smart enough to learn the Case number system.
5 -- 530 model
4 -- Gas variation (A 3 would mean diesel)
0 -- Utility/Standard Variation (A 1 would mean general purpose/rowcrop) On the bigger tractors I think, (but not sure), a 2 is a western, a 3 is a high crop and a 4 is an orchard.
The numbers can also be followed by a letter or two. For example 631-C-H
6 -- 630 model
3 -- Diesel
1 -- General purpose/rowcrop
C -- Case-o-matic
H -- High speed road gear
I hope this helps.
james Hurt
04-03-2008 08:44:34
 Re: S/N Model # Mis-match in reply to JICase, 04-01-2008 19:06:19
Your info was timely and welcome. I need and Operator's manual, Service manual and Parts catalog for this Case Model 530. Which manuals should I choose?
Also thanks to Tom & JGarner.
JICase
04-03-2008 22:04:19
 Re: S/N Model # Mis-match in reply to james Hurt, 04-03-2008 08:44:34
The Ops manual is always good for general maintainance info and are cheap to buy so thats a no brainer. A parts manual is also fairly inexpensive, but you can look up parts for most models on the CNH website and print the pages you need. A service manual will run you into some money on ebay, but if you don't get too deep into repairs, an IT book from Tractor Supply may be all you need. It's a condensed version and can be vague, but will get you through the easier repairs.
Just depends on what you feel you need.
Also, watch out for serial number breaks on the manuals as Case changed the 530s quit a bit during the ten year run. You won't find any info on Diff locks, Independent PTO, Draft-o-matics and Hydrostatic power steering in the early books. Good Luck!
Tom Railsback
04-01-2008 13:24:07
The dealer probably has not been around long enough to know that 540 is a variation of the 530 series.
JGarner
04-01-2008 14:32:26
 Re: S/N Model # Mis-match in reply to Tom Railsback, 04-01-2008 13:24:07
If you ask him he is probably more familiar with models like A, B, H, M, 706, WD9, etc. or he may be too young to remember J.I. Case and not CNH either. (<:
My Case 630 series tractor is a 641 according to my ops manual.
