coil
Kevin in Iowa
04-01-2008 10:16:24
So I was going to give my 830 a tune up this past weekend..points,condenser,wires and coil. Well I went to the local NAPA store and got a coil without really paying attention, I told them it was for a tractor and he said he new exactly what I needed. When I got home the instruction sheet said to "not install on a vehicle with a resistor or with resiistance built into the wiring harness" so does this 830 have resistance built in? Its bone stock except for an alt in place of the gen. Thanks in advance
mEl
04-01-2008 15:53:58
 Re: coil in reply to Kevin in Iowa, 04-01-2008 10:16:24
Check on the front gas tank support. I believe you will find one there. mEl
Den N Ms
04-01-2008 16:47:27
 Re: coil in reply to mEl, 04-01-2008 15:53:58
Keven,mEl is correct,It has a resistor by the support part # A24504 RESISTOR .You could use the coil you have by bypassing the resister.Or if you are sure that the resistor is good go back and exchange the coil for one that uses a external resistor.
