680B Inframe Oil Pan Removal
KevinT
03-31-2008 09:18:41
I have a 68 680B CK with a A267D diesel that I need to replace a piston and sleeve on. Top end is off and looks like I had a water leak on # 3 cylinder. I hear it is possible to do an inframe rebuild on this but looks like I need to pull the front engine mount to get the oil pan to clear. Does this sound correct? And if that is the case, will the roof and radiator support be able to hold the weight of the engine if I lay a steel beam across them and chain it up? Thanks
