Case LA and 500 radiator interchange?
thehickdaddy
03-30-2008 12:06:33
just wondering if a case la radiator will fit a case 500?
Walt davies
03-30-2008 22:29:52
 Re: Case LA and 500 radiator interchange? in reply to thehickdaddy, 03-30-2008 12:06:33
According to Case the Radiator cores are the same number. A8223 and still in stock for both of them.
Walt
Tom Railsback
03-31-2008 08:36:16
 Re: Case LA and 500 radiator interchange? in reply to Walt davies, 03-30-2008 22:29:52
I should have made my post clearer: the only difference is in the top tank and it may not be a problem as both outlet pipes have the same bolt pattern.
Tom Railsback
03-30-2008 15:56:44
I don't think so; the tractors use different types of water pumps and the connections from the top tank to the engine are completely different. You can check the online parts books at CNH.com.
