VA Rocker Arm Tips
gearheadmn
03-30-2008 06:54:41
The tips on the rocker arms on the end that contacts the valves are quite worn. I haven't found any sources for replacement rockers or the tips alone, (it appears that they would be pretty easy to press in and out). Any ideas? I guess that I can grind them down and re-use if need be but it wouldn't be the ultimate I'm sure. Thanks.
george md
03-30-2008 20:16:46
 Re: VA Rocker Arm Tips in reply to gearheadmn, 03-30-2008 06:54:41
If your rockers are too worn to just grind , I
Have the material to build them up and the tool
to grind them .
george
Repaired SC rockers
third party image
gearheadmn
03-30-2008 15:38:00
Thanks for the tips guys
Bruce Nelson
03-30-2008 09:02:11
A lot of valve grinders have a rocker arm attachment meant for taking care of this problem. Check with anybody that reconditions cylinder heads and they should be able to regrind your rockers, easily, or send them to me, I can grind them. Bruce
Gene Dotson
03-30-2008 09:00:12
I have a rod and pivot setup that I grind mine on the valve grinder wheel that is usually used for grinding valve clearance. It is on a swivel base and rhe rocke arms set down over a rod with a washer welded on for a rest... Gene
Jim McVay
03-30-2008 08:33:59
I used a 90 degree die grinder with the twist lock sanding discs to sand mine down to remove the high spots that were not worn from the valves. If yours are really bad you should be able to buy a good used set.
