Crack in block
gearheadmn
03-30-2008 06:51:07
My VA has a hairline crack on the bottom side between cylinder sleeves 1 & 2. It had been epoxied before and the epoxy worked loose. The tractor has been in the family for over 50 years and no one can recall any major repairs ever having been done, (I'm afraid that Dad is no longer with us and unable to directly answer any questions). I am planning on trying the epoxy approach again. Has anyone had any experience with this before? Thanks.
Jim W.
04-04-2008 06:29:32
 Re: Crack in block in reply to gearheadmn, 03-30-2008 06:51:07
I have never seen the bottom cracked, but nearly half the VAC's I have been in had cracks at the top between the sleeves. We cut a small notch in them and epoxy them and have never had a problem with one. With the crack at the bottom, it shouldn't be any different. If I understand where you are talking about correctly, there shouldn't be any trouble with water and oil.
1stout
03-31-2008 15:02:30
my father in law has a couple blocks. I'm guessing that your in MN, let me know. We're about 15 miles from the cities.
DKase
03-30-2008 07:57:31
If the crack is between the water jacket and the crankcase your block is junk. No matter how you try to repair it the stress along with the temp changes will open it up again. Antifreeze in the oil is a recipe for dissaster. Should be easy to find a different block for a VA.
gearheadmn
03-30-2008 08:15:22
 Re: Crack in block in reply to DKase, 03-30-2008 07:57:31
Ouch!
TimBinWV
03-30-2008 17:20:42
 Re: Crack in block in reply to gearheadmn, 03-30-2008 08:15:22
Does the VA have the continental engine? I have a rebuildable shortblock for a VAC,in WV.Email is open
