David Brown 995 Cracked Water Jacket
Walter Buller
03-29-2008 22:28:02
I just bought a DB 995 with about a 6" crack in the outer water jacket. It"s been repaired with JB Weld or something. The tractor runs great. Is there anything I need to be concerned about in the future relative to this crack or anything else on this tractor? Thanks guys.
Larry59
03-31-2008 18:56:57
 My thoughts on this in reply to Walter Buller, 03-29-2008 22:28:02
I did not want to change my thermosta in my truck cause it had a summer one in it and worked good. So for cold winter months I stuck a piece of card board in front of radiator and got all the warmth it needed doing that. Can be done on tractor for quicker warm up's....Took it out just today for the spring time is here. Other then all this rain that has been coming down.
Gard
03-30-2008 05:10:52
 Re: David Brown 995 Cracked Water Jacket in reply to Walter Buller, 03-29-2008 22:28:02
I bought a Diesel David Brown 990 that had a crack in the water jacket, it had been patched with a small plate bolted over it. Previous owner had removed the thermostat and spring from the radiator cover. Therefore the engine never gets hot (temp gage barely moves) and there is no pressure in the radiator. It has worked fine for the last 15 years like this.
Does anyone think it is important to have a thermostat in an old Diesel engine?
Walter Buller
03-30-2008 07:02:00
 Re: David Brown 995 Cracked Water Jacket in reply to Gard, 03-30-2008 05:10:52
Seems to me that a thermostat would be more important in colder climates to help the engine warm up quicker. But here in the deep south I would say a thermostat is next to useless, and maybe even detrimental when you figure the damage that can be done as a result of a plugged up or stuck thermostat.
