Is it possible? 180* outta time!
JoeBob/IN
03-29-2008 18:26:44
I have been working on a 1270 we got dirt cheap. Real real late model and in pretty good shape. Someone left the air filter cover off and it filled 3 cylinders with water and sat for 2 years. Got it all fixed up and fired it up but was missing on #6. Thought it was injector since that was one of the full cylinders. Swapped out with one we had laying around and still no fire. Ok, there was a reason it was laying around! Took one out of a parts 1370 and still no fire. Ok, bad pump so I swap out to the one off the 1370. Alright! Firing on #6 but... nothing on #1. What the heck. Then it hit me. I had the lines on the pump body and cam lined up on both pumps but is it possible for the pump to be 360* outta time AND still run? Only possible thing I can see wrong since the cam gears never came unmeshed and the pump only rotates 1/2 the speed of the engine. But is it really possible to run?
CAHESS
03-30-2008 09:23:08
 Re: Is it possible? 180* outta time! in reply to JoeBob/IN, 03-29-2008 18:26:44
Should have said engine you are putting pump on needs to be at no 1 cyl firing position (33degrees plus-minus)than match scribe marks.
JoeBob/IN
03-30-2008 18:44:52
 Re: Is it possible? 180* outta time! in reply to CAHESS, 03-30-2008 09:23:08
I don't think it is outta time as I changed it already and definately no fire. It is possible to have the scribe marks lined up and be outta time since the IP rotates at half the speed of the engine. Still can't figure why one pump hits on #1 and not #6 but the other pump misses on #1 and hits on #6! Seems odd to have two bad IP's but I guess it is possible since I know the injectors are good.
CAHESS
03-31-2008 07:54:17
 Re: Is it possible? 180* outta time! in reply to JoeBob/IN, 03-30-2008 18:44:52
Sounds like you need to remove no 1 valve cover-make sure both valves are loose at tdc mark on crankshaft .Scribe marks should match at 33 degree . If you are absutely sure all is well there.(BALANCER CAN BE OFF DUE TO OLD AGE) Than i would renove lines on top of inj pump an use hand primer an see if you are having one of outlets leak fuel. They should not. If you walk away to lunch they should not leak while you are gone.If so there is a bad small copper gasket in top of inj pump that is bad. Thanks to Dawgs advise found that to be trouble on 1370 i worked on.Was lucky an could replace my self.
JoeBob/IN
03-31-2008 09:55:42
 Re: Is it possible? 180* outta time! in reply to CAHESS, 03-31-2008 07:54:17
Going off memory and will check for sure tomorrow but with #1 at TDC the first three rockers are loose. However, that wouldn't explain why one pump fires on #1 and not on #6 while the other fires on #6 and not #1. Almost has to be two bad pumps. Now the question is can I check myself, repair myself or do I have to take it somewhere. We have several compatent shops in the area but they all want money! I like tearing into things anyways and if not too crazy I would like to fix it myself. Is it possible to swap parts from one to the other? Thanks for any and all help.
cahess
03-31-2008 13:53:25
 Re: Is it possible? 180* outta time! in reply to JoeBob/IN, 03-31-2008 09:55:42
I know that cost thing! Since you have spare parts why not hook a injector to pump with spare line-run pump an see if missfiring one is working.As i said i repaired mine. Give me acall i will tell you how. Cell 419-674-3289. Check other post i sent about leaking inj pump
cahess
03-30-2008 08:33:13
Did you make sure when you removed pumps on both tractors you had engine set on no 1 cylinder on compression stroke?
