case 580k gears
jeremy collard
03-29-2008 05:38:44
i have a case 580k and i am struggling to secect gears, most of the time i can select 1st and 2nd but the others are a no no. this has happened before and i traced the fault to the cluth buttons. they were full of dirt causeing a high resistance and blowing the fuse. but the fuse is ok this time, im reasonably confident its not mechanical, if anyone can suggest something i would be very greatfull.
cheers
mEl
03-29-2008 09:41:45
 Re: case 580k gears in reply to jeremy collard, 03-29-2008 05:38:44
what model k do you have , the early is altogether different from the later models, where is the trans shifter located, does it come out of the floor, or is it up on the console by your right arm??
jeremy collard
03-29-2008 09:53:12
 Re: case 580k gears in reply to mEl, 03-29-2008 09:41:45
hi there, right its a case construction king 580k made in 1992. the shifter is located on the console on the right. hope that helps!
cheers
