Case SC
patsdeere
03-28-2008 23:08:22
I was putting the pedal back on my SC. It is the pedal that is right under the operators seat that controls who knows what. It seems like the pedal should engage something when lifted or lowered. When it is in the up position you can feel it rub against some metal part inside the case, but when it is done it doesn't seem to be in contact with anything. Did something break or does the machine have to be running to get the pedal to work right?
Thanks.
patsdeere
03-29-2008 20:44:45
 Re: Case SC in reply to patsdeere, 03-28-2008 23:08:22
Thanks.
garytomaszewski
03-29-2008 07:44:30
Should also have a spring to return pedal to up position.
mEl
03-29-2008 03:40:39
That is the lift pedal for cultivators. The engine running, the pto in gear and running, the pedal when pushed should engage an internal clutch of sorts and the shaft sticking out the other side should rotate 180 degress and then stop in that position. mEl
