converting 830 com
Camboted
03-27-2008 18:20:34
We have an 830 COM that has a bad convertor and also have the back end of an old 400. Does anyone know if the 400 center section will bolt in to replace the COM and turn the 830 into a straight gear drive??
comfortking
03-28-2008 04:35:35
 Re: converting 830 com in reply to Camboted, 03-27-2008 18:20:34
It will work. You need to change the top input shaft.
Jim B
03-27-2008 20:31:46
Ted, are you aware that the COM converter is not a welded/sealed unit, like most converters made today.
It can be disassembled and perhaps worth the effort to see want may be wrong internally. We installed new converter lock-up clutch plates in our 800 COM over twenty years ago and found the converter to be quite simple inside.
Repair may be simpler than grafting a 400 center section and midway thru finding out it won't work.
Good Luck, and thanx for the effort to keep the Ol' girl running.
INCase
03-27-2008 18:56:38
I believe they should (I hope so, I'm doing the same thing, almost). You will have to switch flywheels ect. There may have been some difference between the gas and diesel flywheels too. Others will correct me if I'm mistaken. Did you find a mechanics instructor volunteer yet?
