David Brown 990 Front Loader Hydraulics
Mike Gajda
03-27-2008 08:15:19
My neighbor has a DB 990 that he is putting a Case Loader on. All appears to �hook-up� well. He doesn�t want to hook up the hydraulics to the rear-end valves, is there another way to accomplish this?
Thank you in advance,
Mike
ArleninOr
03-27-2008 10:51:32
 Re: David Brown 990 Front Loader Hydraulics in reply to Mike Gajda, 03-27-2008 08:15:19
Steven is right. Use a power beyond block. If Elmer doesn't reply I have those blocks also.
Steven Meckstroth
03-27-2008 09:53:49
There is an option called a power beyond valve. It is a plate that replaces the cover plate on the remote valve.
It has two line. One is pressure, the other return line. You couple the loader control valve into it.
When the loader is not installed, the two lines are connected together to complete the circuit. (If not done, you will deadhead the pressure from the pump.)
Elmer is a frequent poster on this site. He makes new power beyond plates.
Steven
