SC magneto
Ken Christopher
03-27-2008 05:11:50
I have a question regaurding my magneto. Had it rebuilt about 3 years ago, but haven"t used the tractor probably more than 100 hours since then. I recently have been re-assembling the tractor after teardown, and was trying to get the mag to fire on # 1. It seems that no matter what spark plug wire I am testing, it sparks at every other impulse. Now how am I supposed to figure out where # 1 is with this happening? Is something wrong with my newly rebuilt magneto? It is the Case 4-JMA magneto. I would really hate to get rid of it if I don"t have to. Tractor is still all 6 volt, and that is the way I planned to keep it. I also ordered my new gauges and grille emblem off of ebay today. One step closer!Confused..... ..... ..
iluvcase
03-27-2008 11:16:08
 Re: SC magneto in reply to Ken Christopherson, 03-27-2008 05:11:50
Ken: I forgot to mention this in case you did'nt already know this. I was told by an old magneto repairman to use only the metal core spark plug wire ( copper core is great). DO NOT USE the carbon filament wire as this wire acts as a resister and cuts down the rise time of the high tension voltage..... this wire is used to reduce the interferance with radios. The old mags simply can't drive this new wire. I put the original cloth copper cored wire on my "SC"( It has the JMA mag on it). You can get this wire in many different colors.I used the flat black wire on mine.
Ken Christopherson
03-28-2008 04:57:25
 Re: SC magneto in reply to iluvcase, 03-27-2008 11:16:08
I have copper core wires on it now. Took the cap off last night, and I am not real familiar with magnetos or distributors. But, if I had to guess, the tab on the back of the large gear (rotor?) should point towards whatever wire when ready to fire? I got that pointing to # 1 and tested it. Seems to fire on #1. Went throught the cycle, seems to fire on #1 when it is supposed to. This should work if I guessed which part is which....? Thanks!
iluvcase
03-27-2008 10:37:55
Ken: I do'nt know why but; the Case mags seem to fire like that....mine do. Pull your cap and set it to fire on number one cyl. and then time it to your tractor. I 'm sure you wo'nt have any more trouble. Trust me i've been there and have done exactly as you have wondered.....your mag is OK.
patsdeere
03-27-2008 09:01:46
I would pull the cap and check for rust/dirt/junk that might be blocking the contact point on the inside of the cap. Are you using the spark plug to test it? If so, I would try another spark plug since they can go bad. Have you tried switching wires around to eliminate the possibility that it is a bad wire?
If that all looks good then you will have to find somebody else that knows something more about them than I do.
